EDP.PortTimerFail
Description
The EDP port instance was created but the timer to send out the EDP PDUs on this port failed.
Remedy
Disable EDP on this port and enable EDP again. If this message continues to appear, the system might be short of resources. Contact Extreme.
Severity
Error
Message Text
Created port %slot%:%port%, but unable to send out EDP PDUs on this port due to failure in creating send timer.
Message Parameters
Name Type
slot Slot
port Port
